ODT Program
serdagi
Hello, I want to draw a door-window with ODT, but I am getting an error like below How can I fix the error and run the program. good work
Hello Mr. Hakan, the file you sent did not solve the problem. Also, the file name you sent is different from the error dll names?
"serdagi":1a4mcban" said:
Hello Mr. Hakan, the file you sent did not solve the problem. Also, the file name you sent and the dll names that gave the error are different?
Yes, I added another dll in my previous message. Will try the attached dll are you?
"serdagi":3tirq36b" said:
Hakan, the program is open, thank you. I added what you sent first, should I delete it
Delete it, if the program asks for a dll, you can replace it again.
Hello, ideCAD ODT program is used in ideCAD Architecture to add new door/window elements to the Door/window library and to expand the library. Data is not exchanged with any program. Take it easy, good work.
