erdoğanaşık
When I edit object properties, line, wall, door, window etc. I'm waiting for about 4 or 5 seconds for the edit window to open, it wasn't like this in previous versions, what could be the problem.
Hello, if you can add your project, I will try to help"erturan":btrl7803" said:I read and applied these steps above, but the problem could not be resolved.
no one to answer?"erturan":1wy2yw02" said:after I followed the steps you showed in the project in question, I got a positive result and the problem was resolved. But I started a new project, the same problem appeared again. Will I have to follow these steps every time I start a new project? settings are reset. Do I have to re-do these settings every time?
Hello, Make your own settings once using the last architectural template that came with the program and save it as your own template. When you start a new project or have a problem, you do the operation with that template and so on Your own settings will be loaded. However, what I wrote does not apply to icon customizations.It is for settings such as color, pen, etc. If you will use the icon customizations, you will do it again until a new update comes."erturan":3blo5xt6" said:hello, after I followed the steps you showed in the project in question, I got a positive result and the problem was resolved. But I started a new project, the same problem appeared again. Will I have to follow these steps every time I start a new project? Then all the settings are reset. Will I make these settings again each time?
