masonry structures
erşahinler
hello, idecad is a good program to use in static and steel, it is very nice to follow the regulations. Although reinforced concrete and steel structures are in the majority today, our citizens living in villages have financial difficulties. That's why masonry structures are made. Is it possible to bring masonry feature as idecad or do you have an update plan for masonry structures.
"engineer":24fd4es1" said:
Can we solve a masonry structure in the current version?
-Mastery structures are not designed and drawn in the program. However, they can be modeled in such a way that they can be analyzed. You can enter the walls with the curtain object and enter the walls according to the material properties of the masonry structure. you need to define a new material.You can do this by adding new material from the building tree by changing the elasticity module and unit weight of the concrete.The cross-section effects after the analysis should be examined and all necessary verifications should be made by the user (not automatic) Good work
