Hello, I had a problem with the same issue for a different project before and I shared it with you. Can you review the attached project and see where the error is? I think the current system should recover but no matter what I do I can't get rid of the siege error. Of course, it is normal to have it in some regions of the system, but there are regions that I cannot make sense of. At these points, when I analyze the column dimensions to understand the cause of the problem, the result is the same. I have this problem often, the same project can be solved with different programs with the same system. The reason why I did not update the program is due to the comments of other idecad users around me that it is worse after the last update. Attachments:
Log in or register now.
