Hello, How can I decorate the interior, wall or facade, which continues both horizontally and vertically at the same time? I could not connect the jamb section with the extended object. Good work...
Re: Wall Decoration Hello, You can define jambs around your windows or doors. Defined jambs will rotate both horizontally and vertically around your door or window. You can make the desired settings and profile selections for the horizontal and vertical parts of the jamb settings. Good work..
