HakanŞahin
Administrator
Dear users, you can download ideCAD Static 6.54 version from the link below. This version has been removed from access. Click
You do not have permission to view link
Log in or register now.
for newer versions. ideCAD Static 6.54 version: 1. General improvements 2. Adjustments in progress payment programs integration 3. In Ver 6.2007, when clicking "Beam name while in Beam reinforced concrete configuration tab", the possibility to edit all reinforcements of the beam is restored in Ver 6.54 made operational. ideCAD Static 6.53 version: 1. Option to draw in wall details in the order TOKİ wants 2. Besides the condition that the beam reinforcements are left in the wall up to 50fi long, it is possible to extend it until the end of the wall and make a miter 3. Beam assemblies can be mounted on the support combine/unjoin option 4. Option to write total number of stirrups in beam expansions 5. General improvements 6. Update in HTML and what is it help ideCAD Static 6.52 version: 1. Ability to interfere with reinforcement overlay and column/wall anchor reinforcement lengths 2. General improvements ideCAD Static 6.51 version: -General improvements ideCAD Static 6.50 version: 1. New beam expansions - Inclined beams expansions - Dimensioning the transition lengths of reinforcements according to the axis system in beam expansions - Optional display of beam elevations - Creation of cross-section lines for beam opening for each beam span and drawing beam sections - Sa Making suspension reinforcement drawings in the planned beam area - In beam settings; Options for reinforcement transition conditions and bending for beam extensions - Showing the reinforcements in beam sections with their pose numbers - Measuring the overlap lengths in reinforcement joints - Automatic overlapping when the maximum reinforcement length is exceeded in single span beams - In similar floor beam drawings, changing between floors Also showing the pleat, flat and stirrup reinforcements 2. Writing the project, drawing, detail and opening and 3D project data to the PDF file. Thus, the possibility of examining the project by others without a program - Optionally transferring the 2D details and drawings in the project with pen thicknesses - Transferring the 3D model separately and examining it in 3D in the pdf file - Writing the whole project as pdf - Transferring the plans and drawings in the pdf file with indexing and pdf file so that floor plans and details can be accessed easily - Ability to transfer drawings with the choice of architectural or formwork plan mode 3. New performance analysis system and reinforcement reports - Performance analysis according to the minimum performance target foreseen for the structure - Estimation of the probability of exceeding the earthquake for the targeted performance level program - 2-stage non-reinforced and reinforced structure analysis can be done consecutively, automatically, at once - Performance analysis of only the entered structure can be performed - Selective reinforcement reports dialog - Calculation phase during performance analysis Dialog listing of networks - Existing structure/reinforced structure comparison reports; existing structure/reinforced structure displacements; floor forces; floor information; earthquake parameters etc. reports - Element ductility checks; Explanations on whether the element is brittle or ductile in the report - Indication of the cause of element damage in the performance report - Option to take into account the crossties in the column Vr shear force calculation 4. Application of TS498 Article 13 Live Load Reduction 5. Automatic naming possibilities, especially for elements with different rigid diaphragms - Automatic Ability to rename names in naming - Ability to store the names used after object naming in memory - Option to name columns in curtain size for one direction or to name them separately for x and y directions 6. New reinforced concrete configuration tab in the Beam Reinforced Concrete dialog. -With new look; drawing the beam expansion in the dialog -Tracking the areas of missing and excess reinforcement -Following or applying information such as bending, joining or partial transition of the reinforcement on the supports 7. New user defined element loads report 8. Showing the beam-column connection shear safety calculation details in the column reinforced concrete dialog 9. Beam displaying deflection and crack control calculation details in the reinforced concrete dialog 10. Finding and selecting an object selected in the plan in perspective view with the "Find in Perspective" command 11. Option to make complete stirrup compaction on beams 12. Complete stirrup compaction option in columns 13. When floor is defined in floor general settings automatic export of indices 14. 3D block import/export 15. In general settings; Anti alias opportunity to show object edges properly in perspective images in 3D working windows 16. Ability to give the same slope to more than one object (floor, beam) at the same time. Thus, it is possible to enter the inclined floor/beam systems much more easily 17. Ability to change the compaction length value of the bottom of the column 18. Automatic consideration of the basement walls in the calculation of the column length (ln) and the length of the lower compaction zone 19. When the basement curtain is connected to the column; In column shear safety control, the clean length of the column remaining from the height of the basement shear should be taken into account. 20. In the general report of the earthquake regulation, the R coefficient is recommended under necessary conditions. 21. Changing the length of the header zone on curtains. With this opportunity, the length of the headboard area of the curtain can be changed on all floors and indirectly the critical curtain area can be changed. 22. Possibility to define header area for panels that do not require a header area according to TDY 23. Ability to define different rigid basement floor numbers in X and Y directions 24. Automatic sectioning in formwork and foundation application plans - Sectioning in formwork or foundation application plan - Changing section line properties - Marking the section line and renewing the section - Creating the desired number of section lines - Moving the section line and renewing the section according to the moved place 25. Integration with OSKA progress payment program -Reading unit pose lists -Transferring project quantity and calculations 26. Integration with AMP progress payment program -AMP' Reading the database from -Transferring the project quantity and calculations 27. Ability to automatically close the project layers, drawing settings, etc. with a single click with the "Make architectural/statically compatible" commands 28. An object selected in the plan can be displayed in perspective view with the "Find in perspective" command. find and choose 29. Option to see only architectural or formwork plan objects while working in the perspective window 30. Black and white hidden line and border line solid model options for perspective display formats 31. Applying the image configuration to all floors 32. "material name" with "description" in building components option to show 33. Align and distribute commands
