ideCAD Static 6.53
HakanŞahin
Administrator
Dear users, you can download ideCAD Static 6.53 version from the link below.
ideCAD Static 6.53 version: 1. Drawing in the curtain details in the order TOKİ requested option 2. In addition to the condition that the beam reinforcements are left in the wall up to 50fi long, it is possible to extend them to the end of the curtain and make a square if desired 3. Option to combine the beam assemblies on the support / not to combine them 4. Option to write the total number of stirrups in the beam expansions 5. General improvements 6. HTML and this Update on what's help ideCAD Static 6.52 version: 1. Ability to interfere with reinforcement overlay and column/wall anchor reinforcement lengths 2. General improvements ideCAD Static 6.51 version: -General improvements ideCAD Static 6.50 version: 1. New beam expansions - Inclined beams expansions - Dimensioning the transition lengths of the reinforcements in beam expansions according to the axis system - Displaying the beam elevations as an option - Cross-section lines in beam openings for each beam span and drawing beam sections - Making suspension reinforcement drawings in the inserted beam area - In beam settings; Options for reinforcement transition conditions and bending for beam extensions - Showing the reinforcements in beam sections with their pose numbers - Measuring the overlap lengths in reinforcement joints - Automatic overlapping when the maximum reinforcement length is exceeded in single span beams - In similar floor beam drawings, changing between floors Also showing the pleat, flat and stirrup reinforcements 2. Writing the project, drawing, detail and opening and 3D project data to the PDF file. Thus, the possibility of examining the project by others without a program - Optionally transferring the 2D details and drawings in the project with pen thicknesses - Transferring the 3D model separately and examining it in 3D in the pdf file - Writing the whole project as pdf - Transferring the plans and drawings in the pdf file with indexing and pdf file so that floor plans and details can be accessed easily - Ability to transfer drawings with the choice of architectural or formwork plan mode 3. New performance analysis system and reinforcement reports - Performance analysis according to the minimum performance target foreseen for the structure - Estimation of the probability of exceeding the earthquake for the targeted performance level program - 2-stage non-reinforced and reinforced structure analysis can be done consecutively, automatically, at once - Performance analysis of only the entered structure can be performed - Selective reinforcement reports dialog - Calculation phase during performance analysis Dialog listing of networks - Existing structure/reinforced structure comparison reports; existing structure/reinforced structure displacements; floor forces; floor information; earthquake parameters etc. reports - Element ductility checks; Explanations on whether the element is brittle or ductile in the report - Indication of the cause of element damage in the performance report - Option to take into account the crossties in the column Vr shear force calculation 4. Application of TS498 Article 13 Live Load Reduction 5. Automatic naming possibilities, especially for elements with different rigid diaphragms - Automatic Ability to rename names in naming - Ability to store the names used after object naming in memory - Option to name columns in curtain size for one direction or to name them separately for x and y directions 6. New reinforced concrete configuration tab in the Beam Reinforced Concrete dialog. -With new look; drawing the beam expansion in the dialog -Tracking the areas of missing and excess reinforcement -Following or applying information such as bending, joining or partial transition of the reinforcement on the supports 7. New user defined element loads report 8. Showing the beam-column connection shear safety calculation details in the column reinforced concrete dialog 9. Beam displaying deflection and crack control calculation details in the reinforced concrete dialog 10. Finding and selecting an object selected in the plan in perspective view with the "Find in Perspective" command 11. Option to make complete stirrup compaction on beams 12. Complete stirrup compaction option in columns 13. When floor is defined in floor general settings automatic export of indices 14. 3D block import/export 15. In general settings; Anti alias opportunity to show object edges properly in perspective images in 3D working windows 16. Ability to give the same slope to more than one object (floor, beam) at the same time. Thus, it is possible to enter the inclined floor/beam systems much more easily 17. Ability to change the compaction length value of the bottom of the column 18. Automatic consideration of the basement walls in the calculation of the column length (ln) and the length of the lower compaction zone 19. When the basement curtain is connected to the column; In column shear safety control, the clean length of the column remaining from the height of the basement shear should be taken into account. 20. In the general report of the earthquake regulation, the R coefficient is recommended under necessary conditions. 21. Changing the length of the header zone on curtains. With this opportunity, the length of the headboard area of the curtain can be changed on all floors and indirectly the critical curtain area can be changed. 22. Possibility to define header area for panels that do not require a header area according to TDY 23. Ability to define different rigid basement floor numbers in X and Y directions 24. Automatic sectioning in formwork and foundation application plans - Sectioning in formwork or foundation application plan - Changing section line properties - Marking the section line and renewing the section - Creating the desired number of section lines - Moving the section line and renewing the section according to the moved place 25. Integration with OSKA progress payment program -Reading unit pose lists -Transferring project quantity and calculations 26. Integration with AMP progress payment program -AMP' Reading the database from -Transferring the project quantity and calculations 27. Ability to automatically close the project layers, drawing settings, etc. with a single click with the "Make architectural/statically compatible" commands 28. An object selected in the plan can be displayed in perspective view with the "Find in perspective" command. find and choose 29. Option to see only architectural or formwork plan objects while working in the perspective window 30. Black and white hidden line and border line solid model options for perspective display formats 31. Applying the image configuration to all floors 32. "material name" with "description" in building components option to show 33. Align and distribute commands
Re: ideCAD Statik 6.53 new version Hello.. First of all, I would like to thank you for the work done and wish you success and ease in your work, and I would like to share my views on a few issues... Beam expansions have become beautiful in all aspects, they are highly appreciated.. I believe that it is necessary to integrate the rib, cassette and continuous foundation beams into the program with the same drawing format. I also think that improvements should be made in the raft foundation. For example, the dimension lines showing the distances where the additional reinforcements are valid, the intervention to the additional reinforcement lengths (minimum additional reinforcement length option), fractional Ensuring that additional reinforcements come out in clearer dimensions by rounding. In order to make the pleat and flat reinforcement texts look good (eye pleasing) in the mold plans, writing the sheets one after the other at the same level will make the sheets even more beautiful. Thank you İdeYAPI..
Lock problem First of all, I wish you success in your work. I have installed the latest version, but intermittently it has a lock problem and it closes by itself. I would be glad if you are interested in the matter.
Re: ideCAD Static 6.53 new version
"dester":3ssq84fb" said:
I have installed the latest version, but intermittently, the lock problem occurs and it closes by itself
The problem is not with the program, but with the lock itself It seems like. Could you explain the problem a little more? What message are you getting...
Re: ideCAD Static 6.53 new version Congratulations, How can I get back to "build tree" after changing the display configuration once in this new version?
"buzadaM":197n9aox" said:
Congratulations, How can I get back to the "build tree" after changing the display configuration once in this new version?
Toolbars Right-click on an empty space, and select the Structure Tree line in the menu that opens.
Re: ideCAD Statik 6.53 new version When sectioning, the hollow filling material is taken at the same height as the rib beam, instead of a clean height, for your information.
Re: ideCAD Statik 6.53 new version Hello... Thanks to everyone who contributed to the 6.53 version. In the attached project, I encountered some problems with the Beam expansions. I wonder if I'm making a mistake somewhere. Good luck with.
Re: ideCAD Statik 6.53 new version SN ZEKİ78 THE SAME ERRORS ARE IN MY SOLUTION. IT IS HIGHLY LIKELY TO HAVE A BOOT FAULT. 1-IN YOUR SITE, YOU SHOULD GIVE A CARRIER SYSTEM BEHAVIOR COEFFICIENT of 8. 2-YOU SHOULD GIVE UPPER RIGID BASEMENT FLOOR NUMBER -1. YOUR BASEMENT IS APPROVED BY ENOUGH STRENGTH. GOOD LUCK WITH.
"zeki78":c8eg2jto" said:
Hi... Thanks to everyone who contributed to the 6.53 version. I encountered some problems with the Beam expansions in the attached project. I wonder if I made a mistake somewhere. Easy Come on. It activates the partial reinforcement transition. The program also detects the K315 beam as a normal beam. I made it a right console (with the consoles command). The angle of the K316 beam appears -0 degrees (with this value, the beam is not completely horizontal) and the partial reinforcement transition is marked in the K315 beam settings. Deselect the option and adjust the beam so that the angle is 0 degrees Manually make the beam K316 right console. Similarly, what I wrote for the beams K224 and K232 valid. As for K249; The stirrup lettering seems to have shifted to the left due to the suspension equipment. Manually edit here.
Min beam height problem in floors surrounded by curtains Take it easy. When I updated the last version, it gave a height problem in closed floors surrounded by curtains in the project I was working on. so you can try a sample project. Surround the four sides with curtains, let the aperture be 2-3 meters, define the floor, it gives a minimum floor height error. For your information
"dester":3474ce1z" said:
surround all four sides with a curtain, let the aperture be 2-3 meters, define the floor, it gives an error of minimum floor height. detection is a situation we know, thanks...
scans after getting a pattern plan in the old version, select a defined raster and get its settings, then open the "scan" dialog, select "bitmap scan" and click the "select all" command to select all bitmap scans and "give settings to the object" I was able to convert all bitmap scans in the formwork plan to "defined scan" by clicking the command.
after getting a pattern plan in old version, select a defined raster and get its settings, then open the "scan" dialog, select "bitmap scan" and "select all" I was able to select all bitmap scans by clicking the command and then click the "give object settings" command to convert all bitmap scans in the pattern plan to "defined scan". In the new version, I cannot do this
**Click the scan command. Click Bitmap scanning and Select all commands in order from the scanning assistant toolbar that opens. Bitmap scans will be selected. (Blocked scans are not selected. To be able to select them, blocks must be split with [/b]object split [/b].) Click the Object Properties command. In the Scan settings dialog that opens, select the User Defined Tab. Specify the scan type and click OK. All bitmap scans selected in the drawing area will change to the user defined scan you just selected.
How can we change the place where the cross section will pass while "create formwork/foundation plan section" is selected while getting the formwork plan in the new version
**While in the formwork or foundation application plan, after moving the section line to the desired location, right-click on the section line You can recreate the section with the create section command from the menu. You can also redraw the section line and get a new section by clicking the formwork/foundation plan section line from the Drawing menu.
the phrase "hollow brick" in the cross section where can we change the phrase "hollow brick" in the cross section of the hollow floor slabs, it is difficult to explode them all and fix them one by one
