HakanŞahin
Administrator
Dear Users, You can download ideCAD Architecture version 8.61 from the following link: Update from 8.504(164mb):
Log in or register now.
New possibilities developed:[/ b] 1. Commands have been accessed from ribbon menus categorized according to their intended use. Under the grouped menu titles such as facade, visualization, reinforced concrete, it is possible to work faster by easily accessing the relevant commands and subcommands. (The ribbon menu can be canceled or re-selected from General Settings.) 2. Creating a vertical cutting plane 'Clip feature' The structure is cut with a vertical line that you define on the Perspective screen, and the rest of the structure is shown after cutting. You can use the 3d section feature, where you can see the cross-sections of the building elements, especially to examine the interior of the building in detail. 3. Automatic switch to architecture and mold plan modes. For example, when drawing beams, the formwork plan is automatically switched to the architectural plan when drawing walls. 4. Advanced ideCAD Wrep possibilities. Existing possibilities have been enriched in order to make it easier for you to detail and edit your drawings by using two-dimensional drawing and editing possibilities and to prepare ready-to-print layouts. You can open your 3D ideCAD Architectural projects in ideCAD Wrep, take sections and views, create and edit 2D plan drawings, and use them for detailing. 5. Possibility to carry the whole structure in perspective. 3D objects (including floor and formwork plan objects) belonging to all floors of the building are selected and moved at once. 6. Option to display the structure carrier system as a vertical frame 7. Quick move command Fixed issues: 1) The section/view time of the libraries has been accelerated. 2) No rafters are visible in the plan plane. Fixed. 3) We change the material tab where we want to assign material to the siding, and the 'facade cladding texture' tab when we want to assign material to the joint part. Veneer texture changed to joint texture. 4) When you want to see the active floor on the perspective screen, all the combinations on the floors are seen. Fixed. 5) The route line is not copied in perspective. Fixed. 6) If the wall is not drawn with a shift, but caught by the nodal dots of the opposite wall, a small angle remains on the wall, therefore the label direction of the door is drawn incorrectly. Fixed. 7) No matter which window we choose when we come to the dio folder in the installation, even if I choose the material blank, pastel is assigned by the program when I save it as default. Fixed. 8) When we draw two overlapping walls, it does not auto-trimming, and when we double-click on it, it is fixed. Fixed. 9) After the first deformation, the program breaks in the secondary ladder deformation. Fixed. 10) While offset is made with the enter key in horizontal and vertical axis, this cannot be done in oblique axis. Fixed. 11) When we add a wall to the right or left of a windowed wall, the wall scan appears below the window. Fixed. 12) When selecting windows and copying to the upper floor, if the walls on the upper floors are not divided, copying is not done correctly. 13) Midpoint command not working after first closed polygon. Fixed. 14) The window slides when the edge of the place is thrown. The scan stays on the ladder. Scanning is not interrupted by a ladder. Fixed. 15) Although the location label is closed, it appears in the section. Fixed. 16) Oblique axles are also visible in the section. Fixed. 17) When we create a tension rod and take a section, it is not visible at all in the parts where the tension rod is visible. Fixed. 18) When we double-click on the overlay or change its material, the material properties do not appear. Fixed. 19) In the repository, import settings from object / load default settings does not work. Fixed. 20) When the move in scan is called, the outer points in the form of a frame are moved, but the scan itself is not moved. Fixed. 21) There are two steel purlins with the same values, but the perspective views are different. Fixed. 22) Steel purlin divide, combine all does not work. Fixed. 23) The program closes when the Steel/Coating command is clicked and an operation is requested. Fixed. 24) Facade cladding object does not assign material correctly. He gets mixed up when he should assign different materials to the joints and different materials to himself. Fixed. 25) Steel purlin / right button / properties do not open. Fixed. 26) Draw similar object command does not work correctly. Fixed. 27) Tension bar right menu properties won't open. Fixed. 28) The problem of not moving the walls under the windows and doors (refresh). Fixed. 29) Gaps do not work correctly when an angled or split curtain or wall is drawn in the same plane. Fixed. 30) Joint material is not assigned in jointed coating. Fixed. 31) Let the curtain wall be defined as a block in section and appearance. Fixed. 32) When the ground floor and the 1st floor are defined separately, the plasters are defined, but when the 2-2 sections of the whole building are taken, the plaster of the 1st floor cannot be defined. Fixed. 33) When the mirror command is used, the directions of the jambs remain the same. Fixed. 34) Grid lines do not change even when switching to different floors on the perspective screen. Fixed. 35) The symmetry of the extended object is taken incorrectly. Fixed. 36) In floor copying, only the current mode was being copied. Fixed. 47) There is a problem with the wall level when copying floors. Fixed. 48) Purlin and perpendicular are not visible in the plan plane. Fixed. 49) The step parameter has been activated on stairs with lemon beams. 50) In case the curtains are at different upper levels, the location cannot be defined. Fixed. 51) More understandable icons were brought with the ribbon menu, the deficiencies were corrected. We wish you good work.
