HakanŞahin
Administrator
Dear users, You can download ideCAD Architecture 6.53 Demo version from the link below.
Log in or register now.
ideCAD Architecture 6.53 version: 1. General improvements 2. HTML and what is it Update on help ideCAD Architecture 6.52 version: 1. Added 100 bathroom and kitchen accessory library You can view the library images as pdf file from the link below.
2. Added ready-made views for trees and plants in accordance with the architectural display format. Namely; In order to speed up the cross-section in dense tree, plant usage and to eliminate memory insufficiency, these are not actually cross-sectioned, these prepared views are used 3. Speed optimizations were made in the section 4. General improvements were made ideCAD Architecture 6.51 version: -General improvements were made b]ideCAD Architecture version 6.50: [/b] 1. New sections and views: - Automatic rendered rendering in sections - Automatic axial display in sections and views - Possibility of selecting, editing and deleting the section line on the plan - New additions to the cut and seen object groups (railing) Assigning the cut and visible color to building elements such as , jambs, terrain, stairs, profile objects) - Ability to optionally specify 9 different levels (different colors/pencil thickness for different levels) in order to strengthen the effect of the building being in front, behind, and behind the visible objects - Ability to cut a part of the project into section by defining the cut depth - Optionally, the structural elements under the land Hide manually, select a different line type if it is to be drawn - Showing the bill of materials in sections - Automatically writing site names in sections - Optional closed drawing of ribs and cassette floor joists in sections - Ability to make different levels to create a perspective effect on views - Automatic floor level lines, floor names and sectional elevation dimensions 2. Ready-made parametric exterior cladding with joint joint coating, mansion printing and terra cotta coating possibilities 3. Eyelet roofs that are automatically placed on roof surfaces -When placed on the roof, the roof surface is automatically emptied. -The walls of the eyelet roof fit together with the eyelet roof in one click. There is no need to draw walls and cut with the roof again. -According to preference, an eyelet roof without side walls can also be drawn. (To be used on roof terraces) -Eye-eye roofs are selected from ready-made types with 5 different options as one-way slope, 2-way slope (gable roof type), 3-way slope, vault or spline type, and quickly settle on the main roof. -The eyelet is placed on the roof wall with one click of the desired door/window/space. The trimming of the windows with the roof is done automatically. 4. 3D block export/import commands for rendering more than one building (site) within the same project. 5. Writing all project data as PDF with 2D / 3D PDF export facility. Thus, the possibility of examining the project by others without a program - Optionally transferring the 2D details and drawings in the project with pen thicknesses - Transferring the 3D model separately and examining it in 3D in the pdf file - Writing the whole project as pdf - Transferring the plans and drawings in the pdf file with indexing and pdf file so that floor plans and details can be easily accessed -Choosing architecture or formwork plan mode while exporting 6. Rendering according to predefined resolutions and ready-made paper sizes in render settings 7. Align and distribute commands 8. Ability to define cylinder, cone pyramid, tube and user-defined tube objects 9. Ability to define separate materials for roofs, spaces and floors for the bottom/top/side face 10. Automatically collect all the textures used in the project into a directory in order to facilitate the transport of the project 11. Easily change the materials on the object for s Possibility of "Change Material Properties" command in the right-click menu of the selected object 12. Ability to automatically turn off the properties of layers, drawing settings, etc. in the project with one click with the "Make architectural/statically compatible" commands 13. Integration with OSKA progress payment program -Unit pose lists reading -Transferring the project quantity and calculations 14. Integration with the AMP progress payment program -Reading the database from AMP -Transferring the project quantity and calculations 15. Finding and selecting an object selected in the plan in the perspective image with the "Find in Perspective" command 16. Automatic camera creation from the perspective image 17. Writing the file sizes in order to query the density of the libraries in the library settings 18. If a single measure is desired to be given in plan elevation, the rough elevation measure can also be written 19. In order to speed up the perspective in heavy library usage, the "show libraries as contours in perspective" option in the library settings 20. Window to the moon to them; Show/unhide wall tracks in plan view option 21. In general settings; Possibility of anti alias to show object edges properly in perspective images in 3D working windows 22. Option to cast/throw shadows on light sources 23. Capture the midpoints of route objects 24. New possibilities for 3DS objects imported into ideCAD Architecture 6 -Merging into the current project -Import Later scaling of the imported 3ds object -Change the object elevation... 25. Merging the KTP2 files imported into ideCAD Render to the current project 26. In the material settings; In the parts where the folder addresses of the textures are written, copy/paste and change text/additional text can be used to easily find the desired texture and assign the same textures faster 27. Option to show the "material name" with its "description" in the building components 28. Into ideCAD Render Ability to bring imported KTP2 files into the current project by merging them 29. Recall the last render command 30. Option to see only architectural or only mold plan objects while working in the perspective window 31. Black and white hidden line and border line solid model options for perspective display formats 32. Image Ability to apply configuration to all floors
