HakanŞahin
Administrator
Dear Users, You can download the ideCAD Architecture 6.2005 program using the link below:
Log in or register now.
List of works[/ b] 1. The ability to sort by name in the material editor 2. Multiple selection when loading material from archive 3. New 3D libraries in library settings/new library folder 4. Writing the name of the railing in the railing settings 5. Various regulations on curtain wall 6. Render-north direction adjustments 7. If 3d section is active in the door window settings, dio lines appear in the section 8. Program slows down in object edit vs commands and project during recording Elimination of the cases where the dimensions of the stairs grow more than normal 9. The program does not lock when all floors are selected 10. Copy-paste can be made in some cases where there is a library object 11. Line 12. "Object geometry is wrong" message does not appear when trying to select the axis and move it 13. Existing libraries appear in 2D window 14. Level on the panel 15. Program menu being visible in all situations 16. New textures (textures) Good work
