ideCAD Architecture 6, version 6.0012 is ready to use as integrated into the static program. Some of the innovations of ideCAD Architecture 6... Automatic pool drawing Ability to create objects in 3D windows Move, rotate, operations such as symmetry Two-dimensional drawing of objects in the perspective window, display of text, dimensions and axes Automatic ladder design by defining two-dimensional "contours" Ability to define roof details on the roof surface, butt board on the roof details, Ability to intervene in the roof eaves distances separately on each surface Detail with one click on more than one roof surface positioning Quickly editing the names of objects such as axis, space, beam with one click with the automatic name object command Move axis label command Curvilinear and arc slab edge, curvilinear and arc console plates and spaces can be defined with a single command Path (route) object "curves, arcs and lines in one command Drawing as an object" Being able to draw the contour as a path for objects such as roof, flooring and scanning. being able to write text with business typefaces (line alignment, centering, giving different text heights in the text) Ability to edit line texts separately by explode the text block Angle, radius and diameter dimensioning Being able to draw curved, arc and circle beams in one piece as on walls. window placement Multiple viewing of window types in door-window settings Commands to convert panel to beam, beam to panel Autocad 2008 Dwg, Dxf read-write Automatic display of + sign in front of the elevation placed in the positive area in the section window Option to block objects while creating sections and views. Divide into two-dimensional objects Possibility of creating a secondary grid system with auxiliary lines to the grids Ability to recall the last selection Definition of "handrail length" for the stair quantity Incremental-fixed option for door-window label settings If the column misalignment is changed at any floor, it can be changed automatically in other floors as requested. i Define a working plane (Able to work on planes not parallel to the plan plane) Ability to use distance and area commands and route contours (eg. the length of an arc can be measured, the square meter of a curvilinear closed area can be learned.) Ability to create grid lines in the third dimension By defining a special profile with plasterboard, skirting board, border, gutter, horizontal jamb, floor molding, under-roof precast elements, it can be placed on any two-dimensional path horizontally. Special defined profile objects (sweep) created by wrapping will be included in the updates of our 6 users with the version 6.050 that we will release soon.
