I can't define a jamb on the windowsill outside the basement
serdagi
Hello, I am having trouble with the jamb drawings in the attached project. While I can define the jamb on the window sides in the basement, when I define it in other floors, the window disappears, only the jamb is visible, and when we want to make the jamb to cover two windows, the form of the lower window is distorted. I ask for your help on how to fix it. good work everyone
Re: You can't define jamb on the windowsill outside the basement floor Hello, Your problem will be solved if you enter the settings of the siding you have placed and select the 'Under the jamb' option. I wish you good work..
