A ammer New Member Oct 12, 2020 #1 hello friends how to change the Turkish steel code to American code ? and how to print the connection design report as like below image?
N nurgulkaya New Member Oct 12, 2020 #2 Re: how to change the turkish steel code? Hello Ammer; You can change the steel code at the analysis and design tabs. If you change the design code for steel frame, ıt's automatically changed for connections.
A ammer New Member Oct 12, 2020 #3 Re: how to change the turkish steel code? Hi ms nurgul I upgrades my idecad recently from concert to con steel I don't find this option Check image
N nurgulkaya New Member Oct 12, 2020 #4 Re: how to change the turkish steel code? Dear Ammer; Please check the pictures. Also, you should register for the technical support system with You do not have permission to view link Log in or register now. .
A ammer New Member Oct 12, 2020 #5 Re: how to change the turkish steel code? Many thanks mrs. Nurgul The issue are solved I reinstalled the software
