How should the foundation of the villa-patio be
kadirbulut2012
Good work guys, in practice and because I haven't seen it around me, I ask: How should the foundation of the attached villa be? (raft) an example recommendation offered to me is: 50 cm ampatage comes out from the column and building perimeters, and it is singular at both ends under the veranda (which is like a balcony on the ground floor). back to basics. What I'm wondering is, do you have a solution for a project with such an architecture? How did you solve it? Did you bring the raft under that veranda or should that veranda work a console like a balcony and sit on the ground? thanks.
Re: Villa-Veranda Hello. My suggestion: since the number of floors is not high: -- you can reduce the thickness of the foundation by half, -- 50 cm console protrusions can be zero or 25 cm, -- the place you define as the veranda can be placed on the raft foundation you can add. Unver ÖZCAN
