How do I give the stairs landing level?
bstmim.müh.
Hello, it is very urgent, how can I give the landing level to the ladder that I have prepared in the appendix. Necessary notes are also in the file.
Re: CREATING USER LADDER Hello, In the ladder you sent, technically it is not possible to climb to the landing level you want, as 7 steps on the 17.5 pier. However, the desired level is reached by increasing the number of digits without disturbing the dock value you sent. The program will give you the required number of steps when you change the heights of area 1 and area 2 from the stair parameters settings and hold the berth 17.5 from the areas tab. Take it easy, good work.
Re: CREATING USER LADDER THIS IS THE LADDER OF THE OTHER BLOCK OF THE SAME PROJECT I CANNOT SOLVE THE SAME PROBLEM HERE AND I CANNOT UNDERSTAND YOUR PREVIOUS SOLUTION :(
