Hello, You can cut the domes in the desired direction with the help of Cut with the roof using the Vault command. However, the desired 'lion chest' cannot be created automatically, depending on the available space. The request has been forwarded to R&D. Floor wiping is used horizontally between floors. You can use the extended object command for vertical designs on the façade. Take it easy, good work..
