I NEED URGENT HELP.. The reinforcement in two beams on the ground floor is insufficient, I changed the beam size, I did it in complete tightening, I also changed the diameter of the reinforcement, but the same problem persists. I need urgent help. The max margin was exceeded in one column on the basement floor, I said, I made the changes in the beam in the column, but the same problem was not solved.
