atg1978@hotmail.com
I am writing again because there is no answer to my other topic. Dear forum users, my question is what should be the criteria for making hollow floor slabs in a project. So is it necessary to use curtain columns in both directions. Also, when we make a geometry control after creating hollow bar slabs, we get the error that the beam directions of some slabs are not suitable, depending on this. If we continue without correcting according to the program, we will get the wrong result. In my opinion, the beam gear direction, which will be appropriate in terms of continuity, is determined incorrectly by the program. In the old versions, this warning was not available, then, is the hollow floor slabs we solved wrong, thank you in advance for your attention. It is valid for all the settings I want to add. When we first open or install the program, I want to learn the healthiest values that should be the criteria such as all the settings installed in it, floor space, hollow tooth starting range, etc., best regards, take it easy to everyone.
