Glass Railing
serdagi
Hello, I messed up the railing drawing menu of the program a bit, but I couldn't get a glass railing-like drawing that I sent the sample picture of. The railing I want to do will be in a slanting structure, I would like your help on how to do it.
Hello, You can change the default railing settings when you come to the Railing settings. In order to obtain a railing as you have sent in the attachment, you need to delete the handrails and add plates from the plates in the middle. You can make the material glass from the material section written in the plates section, you can choose the profile you want from the railing profile option. Take it easy, good work..
Hello, in order to create the railing in the image, you need to create a plate by accepting some handrails and railings as border regions. If you do not want the balustrades and handrails that you accept as borders to look like frames around the middle glass, "none" should be selected in the profile tab for these elements. Within the connection of the glass plates to the balustrades, the necessary balustrades should be accepted as the border zone and the handrail should be defined at certain levels. We present the railing that we have created for you in the appendix. Good work
