There is no carrier system curtain in your project. The ductility level mixed system cannot be selected. Since DTS=2, Flooring type cannot be solved as unidirectional gear flooring. You can choose the slab system with beams and make a highly ductile solution. From the properties of the basement curtains, select the option "Sub-basement / curtain that does not continue to the upper floor". Good work
