Floor General Settings
ferdiskender
Hello friends ; I'm new to Idecad, I had a question about the floor general settings. Do we include elevation curtains in floor general settings. If yes, can you explain as an example? Thank you.. Good work..
Hello, If you want to see the elevation curtains in section and view, you should include them in the floor general settings. As the first way, when you define the elevation curtains as a separate floor and adjust the floor height as your curtain height, your elevation curtains will be created. Then you can create your other floors. As a second way, add the elevation curtain height to the height of your first floor and enter the height in the floor general settings. Then create your curtains and adjust the upper level value according to the curtain height. Then you can create your walls after entering the settings and entering the elevation value before the wall is drawn. Good work...
