Few Questions
serdagi
Hello, I have questions about a few details about idemimar. 1) Why can't the spaces be designed inclined in buildings with sloping reinforced concrete floors? 2) Why is the plaster option still not added to the reinforced concrete curtains and why do we draw the edge of the curtains while still determining the boundary of the space? 3) When a wall is drawn above or below an inclined beam, why is the wall not drawn according to the slope? (especially 3d visuals are a problem) 4) For example, we should take the walls between the two columns from the column edges to get the right quantity. Does the account change when I get it from their center or from a column defect? Otherwise, it accepts my net distance between two columns/curtains, no matter where we get it. 5) Why can't the inclined curtain be defined as the curved beam (curtain with a curved upper face)? I wish everyone good work.
The location list is a very nice feature, but different options can be given. (according to the exposure number etc.) also, when you get the list, it gives the tag numbers mixed, I think it does it in the order of adding the place, but it would be nice if it was according to the tag number.
Hello, 1-Slope floors; This feature is available because it can be used in areas such as ramps and roof surfaces. However, such an opportunity has not been added since there was no request for such use in the area. 2-In our İdeCAD Architectural version 8.504, a location can be defined without defining the border with the area edge to the sections where the curtains are located. Works on plaster on curtains continue, this will be added in new updates. 3- While drawing the wall under or on the inclined beam, the wall corner points can be given separately from the wall forward settings. 4-Since the columns trim the walls, it does not matter if you draw the wall from the column edges or the center of the column, this does not prevent the correct measurement. 5-Requests on this subject are evaluated and related studies are continuing. Good work.
