Exporting project drawn in IdeCad to 3dsmax?
Meakka
Hello, I can't transfer a small project I drew in idecad 7.019 to 3dsMax. When I save as 3ds it won't open in 3dsmax. Material names do not contain Turkish characters, spaces or shapes. When I throw it as an obj file, the Materials etc. are fine, but the door-window is broken. If I want to export in DWG format, it sounds fine, but the Materials are not. I want the project I've drawn to look like in the ide, let me get the render in 3dsmax.
Hello
"Meakka":3hetcaux" said:
Hi, I can't transfer a small project I drew in idecad 7.019 to 3dsMax. When I save it as 3ds, it doesn't open in 3dsmax. The material names do not contain spaces or shapes in Turkish characters.
3DS file in 3DSMax You cannot open the format with the open command, you need to import 3DS files with the Import command in the File menu. There is no problem with the 3DS file you sent. It can be imported into Max.
When I put it as an obj file, the Materials etc. are fine, but the door-window sounds broken.
We have noted the problem you mentioned.
If I want to cast in DWG format, it sounds fine, but the Materials are not.
DWG format does not contain material information.
The project I want is as it appears in the ide Let me see it, let me get the render in 3dsmax.
Even if you export an object you modeled in 3DS Max and import it into Max again, your project will lose data. When you export the ideCAD Architecture model to 3DS and import it into 3DS Max, you need to make arrangements for materials and Object normals. Making these edits requires intermediate 3DS max knowledge. My advice is to get the renders of your project in ideCAD Architecture, you can get quality renders with little effort.
