Error Tab Disabled Although Error Appears in Report
afrasiyab45
Hello, The project has a 3-storey basement curtain wall, the basement level is +1.00 and the floor heights are 2.70m, with a total building height of 9.10m. After the analysis I made with v10.17 in my file, which I did with idestatic v10.14, but there was no error in the report, it gives an error as follows, but the icons that lead to errors appear passive during the report display. What would be the reason. I especially checked all the curtains, I paid attention to enter them as basement curtains. Have a nice day.
Hello, P.ASN.01 curtain is not marked as basement. Therefore, that curtain is considered as a floor curtain. It should be marked as subbasement. Controls for carrier system type selection have been added to the program in v10.17. According to v10.13, this is why you get a warning at the beginning of the report in v10.17.
Hello. In the 10.17 version, it is checked whether the carrier system type is selected correctly in the TBDY 2018 Analysis settings wizard. According to this warning, you get the error that A11 should not be selected because there is a curtain in the X direction. Check if the basement curtain option is selected for all curtains. Since this error is only checked for project errors in version 10.17, the red arrow signs that you can switch between errors in the report are passive. In the next update, an update was made regarding the error in the Calculation Method and R Coefficient selection table in the Structure summary report. You will also be able to see the error in the report.
