Endpoint Edit
Ismail Hakki Besler
Administrator
The "Edit Endpoint" command, which is up to version 7 and works only in the plan, has been made to work in 3 dimensions with version 8, making it easier to use. In the 8 version, we can select the object and take the endpoint and take it to the new place we want in order to use this feature in plan and end size. In the old 7 version it was also necessary to click the extra "Edit endpoint" command.
T I think that command was more useful because now when you select the object and you are done, the object remains selected, something you do a separate operation for it.
