Elevator well. help...
celikbey
Hello friends. As can be seen, there is a U staircase around the elevator shaft in my architectural project (attached as pdf). How would you suggest I fix the walls of the elevator shaft? Where should I transfer the wall load? Meanwhile, the system was solved with hollow floor and flat beams. One of my thoughts is to stick a beam on the right side of the stairs where the elevator is located, from top to bottom, to support the bottom wall of the elevator and at least have them support the walls. It is not very healthy, but I say this is the most applicable... Your suggestions are important. Thanks in advance.
"saridurmus":1of0vn5t" said:
You can solve this easily by placing panels inside the elevator shaft and it will relax you in the system.
I would like to add to what my dear brother saridurmus said. There is an error in such systems: the beams are not visible or sagging. The curtains are not sufficiently connected to the main system. They are already between floors at the back. In this case, there is an independent tower within the system (depending on the number of floors) at a height of 15-18 m. addition and a reminder...
Thanks Nyılmaz, I made a short introduction because there was a PDF image, it seemed to me that the project had not started. Of course, the Tower has to be connected somewhere.
