hello, I have solved the dilatation structure, one with basement and one without basement, in two separate files, but is there a simple way to combine them while taking drawings?
hello, I have solved the dilatation building, one with basement and one without basement, in two separate files, but is there a simple way to combine them while taking a drawing?
You should carefully examine the effect of two adjacent buildings with a difference in elevation between their foundations. The stresses that occur under the foundation of the high building will affect the basement of the low building.This can change all your calculations.This may be the most important issue you need to solve in your project.
