DOES ANYONE KNOW THE 1/16 PROBLEM ON CURTAINS?
kadir123
Hello there ; In the project, the normal floors and the ground floor are 315 cm, the basement is 125 cm, so the ground floor is 440 cm. In the elevator curtains on the ground floor, the curtain thickness is 25 cm, but it cannot be less than 1/16th of the floor height in geometry control. Can I solve this problem without changing the curtain thickness? and there was no such thing as stapling control in the report, is it not supposed to do it normally? Thank you all in advance.
Hello, - Since there is no floor (diaphragm) at the subbasement level, the thickness of the curtain is 440 cm. It would be appropriate to provide the necessary condition for height. - Stapling control is not performed automatically in the columns that are connected to the basement curtain wall or the basement curtain. In Ver 10.58 version, an option for stapling control has been added on columns connected to curtains. Stapling control can be provided by selecting the option in the Column Properties/Punching Reinforcements tab. You can access the Ver 10.58 version and the work done at the link below.
Good work
