M muhsin34 New Member Mar 21, 2016 #1 I ENCOUNTER THIS ERROR MANY TIMES AT THE POINTS WHERE THE DEEP BEAMS AND CUSHION BARS ARE CROSS-CONNECTED, IT NEEDS TO BE FIXED, I THINK, BECAUSE IT IS A VERY WEIRD IMAGE.
L Levent Özpak Active Member Mar 21, 2016 #2 Re: IMAGE ERRORS Hello, change the trim algorithm of the left end of the K74 beam with the Modify/Object Edit/Object Trim Method command.
M muhsin34 New Member Mar 21, 2016 #3 Re: IMAGE ERRORS Thanks for the information. The problem has been solved.
