Hello. You need to enter the value of 10-4alfaS calculated in the X and Y directions, which you can see in the R Coefficient report"ertub_23":16rfwboa" said:Hello In the project, the ratio of the total shear strength of the total floor area to the total floor shear force gives the warning that it is greater than 0.75. How can it be solved?
No, there is no need. If the curtain header regions are not created, the conditions of DY 3.6.2 are not met or there is a problem in your data entry."ertub_23":26cil4pv" said:Is there a need to place columns on the headers on the curtains? It does not give the head reinforcement drawing in the drawings.
"ertub_23":kiy32u0z" said:HEAD COLUMN DRAWING ON CURTAINS DOESN'T DRAW DRAWING HEADING COLUMNS CAN YOU REVIEW THE PROJECT.
hw/lw Since it is <2, the title region is not created in the curtains. However, if you want to create a header area on your curtains, it is also possible to define a header area in the panel settings "rebar" tab."YasinTezel":kiy32u0z" said:the conditions of DY 3.6.2 are not met if headline regions are not created
