We are making a 2-storey reinforced concrete project, why is the body reinforcement on the curtains more than the head reinforcement? For example, he throws an iron with a diameter of 16 at 7 intervals?
In the panels settings, there is a head reinforcement/total reinforcement ratio. If you haven't changed it, the program's default value is 50%. If we make a statement according to 50%; 1. First find the totalAs based on design effects or the minimum reinforcement ratio, whichever is greater. 2. TotalAs * 50% -> body 3. The remaining 50% -> heading -> 25% for each heading. Minimum reinforcement ratios are also controlled in the headers, whichever is greater is used. Since there are two heads, reinforcement ratios on the panel generally appear as 25%-50%-25%. As mentioned above, it is possible to change this ratio.
