Cross section and appearance
resa inşaat
Hello. After I draw the idecad architecture, I take a section. How can I change the shape of the hollow floor slab, it is 30 cm thick, but it wants it to be straight, ribbed, municipality
Your sectional location has probably passed right through the rib beam. If you shift the place of your section 5-10 cm, you will get the image you want.
Good work, the slab thickness can be entered as 30 cm in the Flooring General Settings. The plate thickness, for example, 7 cm. try making a cut. If the problem is not resolved, attach the project file.
JUST ENTERING HOLDER FLOOR THICKNESS OF 30 CM, IT LOOKS LIKE THE SECOND PICTURE. I WANT IT TO BE TAKEN LIKE THE FIRST PICTURE. THERE ARE ALREADY A PROBLEM WITH OUR DRAWING AS PLATE BUT THERE IS A PROMISE
As cansahin friend said, you entered the floor thickness too much. Send your project easier and we can say something clear. The slab thickness (reinforced concrete part) in the hollow block is entered in the slab section of the program. The height of the ribs (floor teeth) is entered in the rib tab. Check out the sample image. Hollow slab thickness = 10 cm concrete part + 25 cm rib tooth height = 35 cm For such a slab, you must enter 35 cm for the rib height in the program (on the rib tab).
Good work, The operations are given in the pictures respectively and presented to you with the project file. 1. First, create your slab flooring. (Slab thickness as 12cm) 2. Turn your flooring into ribs. ( After completing this process, the slab thickness will remain 12 cm and the rib beam height in the rib settings will be 35 cm.) 3. When taking sections; For sections parallel to the rib beams, pass the section line not through the rib beam, but where the hollow brick is located.
First of all, I apologize for not being able to reply immediately due to time problems. It is one thing to write something with words, another thing to add a picture. See pictures in attached file. If you follow the clock of my computer in the corner of the pictures, you will see the order in which it is done. Or see the picture number. Good luck with. the file is attached.
