COPY WITH REFERENCE ?????????
You can copy the object you want by referencing the point you want. There are two methods I use. Method 1: Select the object, determine the reference point with the clone command, find my reference according to the place to paste and paste it. method2: I usually use the copy method because when you copy, it saves it to its memory, and when you exit the command, use another command and return to the command, you can continue pasting with the same reference point. The application method is still the same :))
