CATCHING FROM NODES
diriliş
When drawing the formwork plan, the beams are off-axis. It does not quite capture the wedding point where the axes intersect. It catches 2-5 cm boat. It does not fit the axles properly. Therefore, some tiles cannot form. Even if you somehow enter the slab, the analysis result does not show the slab reinforcements. Why is this trouble happening? can you help me. greetings.
"diriliş":2uecvuur" said:
hello sir. I have not sent any projects in this program. I was sending them via e-mail beforehand. Greetings
It is not possible for us to understand what the problem is without the project.
you are right. I do not know which method to send the project in this program. For this reason, I could not send a project.
"diriliş":1m1hqra6" said:
you're right. I don't know how to send a project in this program. For this reason, I couldn't send a project.
-You can add the project file from the Plugin upload section below to the dialog where you wrote a message. -If the file size is large, wetransfer etc. You can upload it to the site and give the link.
