Can you check my ideCAD Static v10 project
arembero
Hello, can you comment on the project according to the new direction. I used hollow floor and normal tiling at the same time, is it against the new directive. There is a warning that a limited system should be selected in rollover control. has the selection been made?
Re: ide10control
"arembero":3rdnxrpl" said:
Hello, can you comment on the project according to the new directive. I used the hollow floor and normal flooring at the same time. Is this against the new directive. There is a warning that a limited system must be selected in rollover control What does this mean? Is there another curtain I should add to the curtain group, and finally, have my analysis settings been selected correctly according to the new directive
Regarding the program, when I enter the grid settings, the program closes. After the analysis, there is no problem when getting a report, but after a day it does not report, I get an error. I get a report after install and repair, I would appreciate it if you inform me about it.
Re: ide10 control
"arembero":3tv81sqp" said:
The program closes when I go to the grid settings regarding the program
Hello, This situation that occurs in the right-click menu will be resolved in the next version. You can use the General Settings, Grid Borders tab to make changes
There is no problem when getting a report after the analysis, but after a day it does not report, I get an error. /quote] If you can't get a report, call our ideYAPI Bursa technical service, we can look at the problem by connecting to your computer with remote access. ideYAPI Bursa Technical Service 0224 220 67 17
Re: ide10control
"arembero":3h84mkac" said:
Hello, can you comment on the project according to the new directive. I used the hollow floor and normal flooring at the same time. Is this against the new directive? There is a warning that a limited system must be selected in rollover control. What does this mean? Is there another curtain I should add to the curtain group, and finally, have my analysis settings been selected correctly according to the new directive
Hello, there is no explanation about the use of hollow floor and beamed floor in TBDY 2018. Normally, a part of the floor or some parts of the floor in your project is not available. If you make the floors completely hollow, it would be correct to accept the system as hollow floor (Single-direction threaded flooring) in order to stay on the safe side and apply the TBDY 2018 gear flooring sanctions.In your project, only hollow block flooring was used in console flooring. My opinion is that the system is a beamed slab, since hollow blocks are not used between the curtains and the frames in the carrier system. You still consult the chamber / municipality where you will present the project. You can also convert console floors to slab flooring, if you can go with that admission. If you prefer a high level of ductility, you can choose the A15 carrier system type. In this case, you need to correct the column beam joint shear safety issues. or you can choose the A33 carrier system type with limited ductility level.
