Butt plate beam attachment design report
Onrugrlu
good day, I can't get the design report of the butt plate beam attachment that I designed in the picture, the bolt number is wrong. I did not encounter any conflict situation , I learned that it is generally used in this way in the market , how can I solve my problem ?
Hello there; You can use the join like this, but you won't get the report. To receive the report, the group 1 bolt number must be 2. Since the calculation model of the combination was created in that way, we do not currently provide the report in other cases. However, you have freedom in modeling and drawing, and you can create as many bolts as you see fit. Good work.
"nurgulkaya":28ccojcv" said:
Hi; You can use the combination in this way, but you cannot receive the report. To receive the report, the number of bolts in group 1 must be 2. Since the calculation model of the combination was created that way, we do not currently provide the report in other cases. However, you have freedom in modeling and drawing Good work.
The date you said you can't give right now, we get the same error in version 10.17. I wonder if this will be fixed or will it stay like this forever?
Hello there; The version of this combination, which is also calculated in the foreign literature, is the version containing the geometry we have reported. Yes, the market and the field used and the literature may not always progress the same. This situation exists among the notes, but TBDY 2018 constitutes the agenda of the last 2 years, earthquake regulation issues are in priority in R&D. For this reason, the account of the combination you requested will not come in the very near future. The account of the combination is available in the work list, we just cannot give time. Good work.
