alpaslanbulut
Hello, I have a project with 3 floors without a basement. However, the bottom depth of the foundation is 1.50 m according to the ground survey. should be, the upper level of the basement (ground floor) is 1.00 m. normal floors floor heights are 2.90 m. The raft base will be 50 cm. According to this information, the columns of the first floor starting from the raft foundation are high/low, and I also have elevations on the +1.00 floor. Is it possible for me to pass the +1.00 level without an additional floor/laying? I saw that in some construction sites, they made the first floor column high and filled it up to the sub-basement level. I look forward to your comments and suggestions on the subject, thank you in advance. Note: I haven't entered the project on the computer yet, but my drawing explanation is attached. Alpaslan
