endezyarSG
Hello friends, when I check geometry in my project -beam slab edge overlaps- and beams -small angle object- warning. Do these warnings pose a problem?
Hello, "Beam slab edge overlaps It would be appropriate to correct the " error. The "tile edge" object should be drawn on the empty edges of the slabs. The tile edge should not be drawn where the beam is. The "small angle object" message is a "warning" message. This situation does not constitute an obstacle to solving the project."endezyarSG":kesfrxts" said:Hi guys, when I check geometry in my project -beam slab edge overlaps- and on beams -small angle object- is this a problem?
