Beam (S) Error
s error in the beam does not save the deflection. Increase the pressure reinforcement and re-analyze it.
The file does not open, but my suggestions are; 1. You can control the fixed and live loads on the beams and reduce them if they are excessive. 2. If the system is ribbed, you can design the ribs to be parallel to these beams. 3. You can add additional pressure reinforcement. But this time, you may get a combination error in the relevant column (b), you should pay attention to this.
