Good day, I could not solve the S error in the beams of the K35-K36 stair side of the project I sent attached. I will be glad if you can help, good work.
The file does not open, but my suggestions are; 1. You can control the fixed and live loads on the beams and reduce them if they are excessive. 2. If the system is ribbed, you can design the ribs to be parallel to these beams. 3. You can add additional pressure reinforcement. But this time, you may get a combination error in the relevant column (b), you should pay attention to this.
