beam raft
resesif_07
Hello, I am making a mistake in the beamed raft foundation solution in my project, too many reinforcements are constantly appearing in my foundations, am I doing wrong in the analysis type, can you help?
Except for the continuous foundation beams passing through the middle axis, the other continuous foundation beams appear as one piece throughout. This data entry is incorrect. In fact, there should be a continuous foundation beam between both columns. So, to give an example, you have a 105m long single span continuous foundation beam named TK16, which starts from 1 axis on your A axis and ends at 24 axis. However, since you have 18 columns on the same axis, there must be at least 17 beams. (If you cantilever at both ends, it will be 19.) Fix the continuous foundation beams on the other axles in this way. Note: Other issues related to the project were not considered.
"recessive_07":jpnq0pkc" said:
Hi I'm making a mistake in the rafter raft foundation solution in my project, I am constantly getting too much reinforcement in my foundations, am I doing it wrong in the analysis type, can you help?
Hello, First of all, the beamed raft foundation data entry is incorrect in your project. None of your continuous foundations on the outer axles are connected to the columns. Also Continuous Raft slab edge is drawn under the foundations. Because the raft areas are too large, Continuous Foundation reinforcements may be excessive. You can reach a more economical solution with the raft-free raft slab system. Note: The directions of some of the point loads defined on the columns are given upward. In order for the load to be downwards, minus (-) value must be entered. you can eat. In order to see the loads you have defined in the column; -> Click the right mouse button in the perspective window. -> Click on the 3D Frame line in the menu that opens. The results display dialog will appear. -> Click the downloads option in the display results dialog. -> Click on the Element Loads User line from the load types. -> Check the option that is suitable for the load you have defined from the installation statuses. -> Your loads will appear on the elements. Good work
