Basically the elevator shaft
Acemiii
Basically, is the application I made for the elevator shaft a correct application or is there an alternative better solution? Can you check if there is any mistake in my project settings. Thank you so much in advance. Good work..
Re: MAINLY ELEVATOR WELL Hello. My suggestions: -- X direction A11 R=8 -- Y direction A15 R=7. It doesn't save you from tipping over when you get it. --You should continue with curtain addition or Mixed system. --Can be basic. Unver ÖZCAN
Re: BASIC ELEVATOR WELL first of all, thank you for your interest, Mr. Unver, but it has become more complex, I would appreciate if you could help the project.
