izmirli_35_35
In the attached project, it gives a stapling error on columns S4 and S5 in the basement. Again in these columns, the vertical load gives too much error. I solved this problem by increasing the column sizes though. In order to eliminate the stapling problem, I made the raft base thickness 62 cm. Isn't this raft foundation height too high? Also, are there any other problems with the system? Thank you...
