When I did the analysis, the raft reinforcement seems insufficient. Even though I tried many ways, I could not fix it. Can you specify the steps to be done for my correction and apply this process to my project and send it to me? It does not show the raft in color in the image. Thank you.[/ quote] -In your project, by selecting the superstructure interactive solution option in the Analysis Settings in its current form.Basically, the problem of raft reinforcement insufficiency is solved by making some ampathes (for example, 30 cm each.) Analysis according to the "Enlarge connection area" option in the analysis settings can contribute to the reduction of additional reinforcements. -You have made a superstructure-free solution in the project. You can see the raft shell results by selecting the raft foundation results component in the Visualization dialog. Other project notes: -It is appropriate to select the "underground/non-continuing curtain in the upper floors" option from the properties of the subfloor curtains. It is appropriate to choose the A11 in both directions. It happens every day -When it is done in geometry control, it is seen that there are incorrectly defined floors on the ground floor. You can delete these tiles as described in the link below.
-I recommend checking the wall loads on the floor joists.
