A problem with roof slope
kilicproje
hi guys i am a new member. I did a drawing internship with another program before. I just bought ide 7. I will start with small projects at the beginning of the month. QUESTION 1: My question is, I am inclining the roof in this roof.png picture. From 3 meters to the edge, which is the floor thickness of 17 cm (side elevation 70 cm in the picture). when this happens, beams 3 and 5 get stuck in each other. If I delete beam 3, the console does not save sections from working. Also, column 2 cannot withstand cutting.(When it is 17 cm). Since beam 1 is stuck in the bottom floor kit and column where it touches the floor, it gives a level error. In short, what kind of design method should be applied to make it zero according to the floor below where the roof tile ends. I can send the project to the friends who will help. 2 QUESTION: In the roof problem.png file, when the beam I throw from the middle gets stuck in the curtain surrounding the staircase, I get the error [/u] that the curtain length cannot be more than x times the curtain thickness. Can this be ignored? Also, in 3 dimensions, the roof is not shaped according to the slope. what path should be followed.
