3d Performance
platon24
Hello there; I'm new to the world of idecad and I have problems with the performance of the program (I think). My System: Fx 6200 amd 6 core 3.8 GHZ 16 gb 2133 mghz ram hd 7850 oc 2gb 256 bit graphics card .... My first question is; There is no problem when starting to draw, but as the library content increases, it becomes unable to turn the 3D screen. Is this normal? The drawing I am talking about consists of a workplace, 3 floors, 10-15 doors, a few chairs and a table. It is a simple scene according to the computer I use, but the program drops to 1-2 fps. My second question; After a while, the program stops refreshing itself. For example, I selected an axis, then when I press the esc key to reset the selection, the selected axis still remains lit. It does not go out without interfering with the screen (like zoom in or pan). I understand that the selection is removed, but the scene is not refreshed without a user command because the graphical update has stopped. The buttons in the viewport also lose their clickability. So the button is there but I can't click it. Is this something normal? Thank you for your answers. Enes Aydogan Technician
In your project, you have placed a total of 81 libraries, 27 on each floor, which is not too many. On our computers, the 3d image slides very quickly, so to speak. Even in hardware where you have a much worse graphics card than yours, it is at an acceptable speed. Your problems seem to be caused by the graphics card not being configured properly. I think that the problems will be solved when you install the current win8 compatible driver of the card. (Also in case of axle selection)
I checked the drivers again, they are all the latest version now. Are there any settings or 3rd party programs you can recommend to improve performance. Annoyingly slow. I tried it on a win 7 computer with the same features. The results are the same poor performance. This is the same for everyone who uses an Ati. I would be glad if my friends can give an idea. I might go for a hardware change if that will work. Thanks for your suggestions.
"platon24":2asisw9g" said:
I checked the drivers again, they are all the latest version now. Is there any setting or 3rd party program you can recommend to improve performance. It's annoyingly slow. I tried it on a win 7 computer with the same specs. The results are the same low performance. Is it the same for everyone who uses Ati. I would appreciate if the friends who use it can give an idea. I can go for a hardware change if it works. Thanks for your suggestions.
Hello, call us from our Bursa office. Let's look at the problem with remote access. Tel : 0 224 220 67 17
