You can transfer to Tekla Structures with Demo Version
Re: You can transfer it to Tekla program with Demo Version The steps of importing to Tekla Structures can be summarized as follows: 1) First of all, open the ideCAD Static model you want to import, and follow the "Project > Export > Tekla .dmp" path from the menu to export the model. You save it as a dmp file. 2) Then you run Tekla Structures installed on your computer. Currently, the transfer process can be made to all versions of Tekla Structures from version 17.0 to 2016i. 3) In Tekla Structures, you open an empty model or an existing model that you want to add the ideCAD Static model and wait without closing this software. 4) While Tekla Structures is open, run the "IdeToTekla.exe" software in any of the Turkish or English folders under the "C:\Program Files\ideCAD\ideCAD Statik 8 Demo\ideToTekla" folder, and the version of Tekla Structures that you will transfer from the settings on the right. You choose which elements/features in the ideCAD Static model to transfer. 5) You start the transfer process by selecting the .dmp file you created in the first step with the "Choose a file..." button. 6) Since the transfer process is done with API commands, depending on the size of your model, when you switch to Tekla Structures, you will see that your ideCAD Static model is created here step by step. 7) While the transfer process continues step by step, if there are any profiles that are not compatible with Tekla Structures' library for the profile type/name and material names defined in the ideCAD Static model, warning screens are also opened as a popup menu for the user to define them. The transfer of compatible ones will be done automatically without any user intervention.
Re: You can transfer it to Tekla program with Demo Version Can we analyze a structure modeled in Tekla with idecad steel?
Re: You can transfer to Tekla program with Demo Version Hello; Transfer between programs is from ideCAD to Tekla. It is not possible to transfer from Tekla to ideCAD. With v10, the transfer from Demo version to Tekla has been removed. This option is only available for v10 Licensed programs. Good work.
