HakanŞahin
Administrator
For 6.0011 users, this file takes care of multiple "TextStyle" renderings after dwg and dxf import and slowdown in AutoCAD.
Hello, Mostly autocadte background is black and the colors of the drawings prepared there are also It is determined accordingly. Therefore, we make the background black in the program. If you explain the problems this situation causes in your work, we will determine the precautions we need to take better. In short, we thought it would be appropriate to make the background black. After importing the drawing, we make the background black. We ask you to specify what the problems/troubles are.What happens when we import black, if it is not black, what color will it be, will the program put its own colors, etc. Good work..."siromar":untndnkt" said:Thanks for the file I also want a patch that will prevent the background from turning black when we import something from autocad. Good work
I agree with sn.siromar's complaint about this, I really agree with the import of the background color. then it is not possible to turn white, if this situation is corrected, it will be very good for us."siromar":1akf3zr2" said:Thanks for the file. I also want a patch that will prevent the background from turning black when we import something from autocad. Good work
