Writes (B) next to some columns in the columns
pehlivanozan
I've just started doing projects, as I learned from training videos and friends, can you check my project? When I do the analysis, it says all sections are sufficient, but when I look at the columns from the reinforced concrete design, it says (B) next to some columns. How can I fix this?
Re: KONTROL HELP Hello My Suggestions -- Correct the warnings in the geometry control, --Make the narrow sides of the column 30 cm, --Let the beams center the columns (Some of the B errors are corrected.) --Reduce the floor loads on the attic floor, remove wall loads, --You may need to make an elevator floor, --For Column B errors,
9) There is a B warning in my columns. How can I solve it? Please review. Take it easy Unver ÖZCAN
Re: KONTROL HELP sir, I did what you said and I chose the concrete quality as c30, it seems that the problem is gone. I will give the project to the municipality and can you check it this way?
Hello, My Suggestions -- Get the ladder loads -- Isn't the platform where the elevator machine will be placed in the architecture? --I would make the mezzanine beams 25/50, (K43) --I would support the ladder on the mezzanine beam. --If you put a mezzanine beam, check the short column, Ünver ÖZCAN
