window problem
aysel
Some window and multi-door models that I have drawn in the plans are not drawn in detail when I cut them. I see it as just a line in the wall thickness width. I need to nap
Hi, I think you are using 6.52. When you select 3D Section in the door window settings, it will be drawn in detail. This has been fixed in update 6.53. You can download and use it when it is published on the forum. For now, using it in 3d as I stated will solve the problem.
"aysel":79mw98bw" said:
Some of the window and multi-door models that I have drawn in the plans are not drawn in detail when I take a cross section. I see them only as a line in the width of the wall thickness. I need to nap
